bill johnston
07 Dodge Ram 1500
4.7
Flex fuel
4x4
Driving home, check engine light came on, lean condition bank 1, replaced o2 sensor, cranks but no start, replaced fuel pump as old one just trickled gas out Schrader valve, crank no start, check Schrader valve gas squirts out, hooked up pressure Guage have 83 pounds on rail. Replaced crank and cam sensor, crank but no start, checked engine compression got about 140 average ( its a new motor with only 18,000 miles) have spark, found I have no signal to injectors. Tried starting fluid still crank but no start. There seems to be no fuse or relay for injectors. Plus I would think even if I pulled the injector wires all off it should start with starting fluid. From what I found my truck has a TIPM that seems to have problems. Any thoughts??
4.7
Flex fuel
4x4
