Crank no start, no voltage from ecm fuse
carson59
nevada
5.9 24v CR
Hi. I have a 07 5.9 24v CR 2500
Sat for a bit, went to start, wouldn't start just cranked. Tried cranking again - heard a pop, then burnt wire smell coming from ignition area down there.
-Was throwing a code for crankshaft sensor so replaced that- Still no start just cranks
-was popping the ecm fuse instantly- but now doesn't after doing crankshaft sensor, but now Showing too many ohms and no voltage out of the ecm fuse
-Checked all injectors, none are bad
--everything says bad ecm but just seeing if there is something i may have looked over. tried to track down that burnt wire smell but can't find it, any help is much appreciated
codes thrown 37 323 542
