No trailer brakes
Jaxblake
Colorado
6.4 hemi
2016 ram power wagon.I was hauling my trailer to Iowa a couple days and ago and as I went over a very bumpy bridge my display show the trailer connected then disconnected 3 or 4 times the finally stay disconnected. After the bumps stopped I had no trailer brakes ,the light and everything works but no brakes and the positive pin doesn’t work either but that could be unrelated. I put a new bumper plug in same thing. I know the trailer works pluged it into multiple different trucks and they all worked with the trailer. The pin says it has 28 millivolts at the plug and at the fuse with the gain at 10 and the brake pressed. I’m thinking that it’s the itbm module but not exactly sure
EddiieeG10
Sacramento Ca.
Have a Similar Problem, My Ram wont connect to the Brakes, but to everything else like lights yes.
Trailer works fine with Other Trucks.
Had Ram 7Way Tested and Power Load Test and Ram Connected to brakes and was able to use Gain Controls during power load test.
But still my Ram and Trailer wont connect to brakes! Im GOING CRAZY! I dont know whats the problem?! The Truck or the Trailer!?
The Ram trailer brake output is PWM controlled, so unless an inductive load is present and the correct type of meter is used a voltage reading will most likely be wrong/off. The brake output is in part determined by vehicle speed, the output may not full output while parked.
Figure out why the +12V isn't working, possibly the fuse which I believe is F30. It might be a wiring issue that has effected both the +12V and brake wire going to the back. F11 should be for the brake output.
It still could be the trailer brakes, it wouldn't be the first time someone has reported them not working behind a Ram but does with other brake controllers. While inspecting the trailer brakes there were problems found. You said the plug in the bumper was changed, did you change the trailer side? or the truck side? There have been problems with the jack in the bumper, check the plug behind the bumper.
markabby
Monticello, Kentucky
2020 Limited
i had that same issue....it was a faulty wire on one of the brakes. Once i fixed that, it never came back.
This time i soldered all the connections and wrapped them with tape
2003F350
6.7 CTD
Posted this in another thread. Might be applicable.
What does your plug on your trailer look like?
Does it look like this:
Plug style 1 (crappy)
Or this:
Plug style 2 (good)
In my experience, Ram trucks don't care for the first style - they don't interact with the receptacle on the truck very well. I had issues with that style on my flatbed trailer with my '17 Wagon and my new '22, but it would work fine behind the wife's or my FIL's Fords. My truck had NO issues with our travel trailer, which has a plug like the 2nd style.
I ended up replacing it with the second style, and all the problems with my flatbed went away. I went ahead and upgraded the lights on the trailer a few weeks later to LED, just to make them brighter, but the problems were with the plug.
I THINK what happens is the flat blade style tends to 'swell' a bit after some use, and they don't make a good connection with the receptacle that Ram uses. The second style is set up more like a 'spring' or a clip, and makes a solid connection to the prongs in the receptacle.
joesstripclub
Kansas City, MO
2021 2500 PW
I lost trailer brakes on my toy hauler coming out of the mountains into Denver last summer. Made the dealer come pick up the trailer and they said that one of the brake electrical lines got caught on something and shorted out. They fixed that and I have only seen the trailer brake disconnected quickly flash up once or twice. My trailer has the "good" plug in the above post, just think this truck is a little picky.
noraa73
