No turn signals or hazards
Jack317
2001 dodge ram 2500 here, got home from work last night and parked it with no issues, went to leave today and had no turn signals/hazards. I replaced the flasher relay and replaced the two regular fuses with no luck. Is there anything else that could be causing this besides the turn signal switch itself? Everything else seems to be working fine. Any advice would be appreciated.
Starting to get tired of replacing stuff on this ol' truck. Lol.
EvilSpirit
5.9 Magnum
2nd gen Rams are notorious for pulling wires out of the turn signal switch connector, which can cause many different issues. I'd try turning on the flashers and cycling the steering wheel up and down and see if anything changes. If so, the connector is on the left side of the column under the plastic trim - look for wires pulled out of the connector.
Reactions: Mop
BGW656
