turn signal
  1. D
    Burned out turn signal warning.
    I own a 2013 Ram 1500 sport model. For about three weeks my left rear LED turn signal warning light has been coming on at start up and the left turn indicator fast blinks. This has happened before on the right rear LED turn signal and replacing the turn signal assembly took care of it. In this...
  2. 2
    running light stays on and flashes fast with hood
    My dash left turn signal started flashing fast. I figured that I must have blown a lamp but when I took a look the left running signal was on dim all the time even with the headlights off. When I turned on the left-hand turn signal the front lamp flashed on and off but fast along with the rear...
  3. C
    2019 LED turn signal i op
    My rear turn signal is not work. These are led strips. All the other lights on the taillight assembly work. This entire assembly needs to be replaced to fix the turn signal. 1149$ because of the Mod in the assembly. They don’t sell the tail light without the Mod from what RAM parts department...
  4. Hangar_Gremlin
    Turn Signal Issue
    Good Evening Friends, I have a 2018 2500, my front driver side signal went out, with hyperflash on the dash and hyperflash on the mirror indicator, but normal flash in the rear. I changed the bulb and no fix. Was wondering if anyone else has experienced this? Thinking a wire got nicked...
  5. rubes7202
    Right Rear Turn Signal Light Out
    2015 RAM 1500 Sport. Anyone have an idea of what could be causing this? Only comes on at engine start, then goes away. I turn on blinker and everything looks fine from all corners. I have the stock LED tail lights. I am stumped. Sent from my SM-G988U using Tapatalk
  6. A
    Electrical Issue
    Hey guys so own a 2012 ram 1500. Noticed yesterday that when i shut the truck off and lock it, my drivers side turn signal stays lit-my reverse lights and drivers side brake like stay on and wont shut off. Ive turned my headlights to off and tried it then and it wont shut off still. Put in a new...
  7. R
    Turn signal hot wire
    I need to hook up a camera trigger to the turn signal hot line before the flasher. I don't want it to be pulsating. Anyone know where this can be found? I have a 2020 Rebel.
  8. R
    Front passenger turn signal comes on when braking.
    I have a 2012 Ram 1500 Laramie. I've had it for a few years. I recently noticed that when I hit the brakes the front passenger Amber turn light comes on solid with the brake lights. Then I noticed that the brake lights only come on when you have the key in the ignition. Has anyone had any issue...
  9. M
    LED upgrade complete, now throwing multiple errors
    So I upgraded all my Halogen bulbs on my '18 to LEDs the last two days. The Low Beam, High Beam, Front Turn Signals, Fog Lights, 3rd Brake Light and 3rd Brake Light Reverse lights, Taillight Reverse Lights, and Taillights. Everything up front works with no issues or errors. Everything in the...
  10. D
    Turn signal issue
    2014 Ram Longhorn So my dash computer is telling me that the right rear turn signal is out...but it’s not! The green arrow flashes fast inside, but it is flashing normal outside and the light seems nice and bright. what could I be missing?
  11. D
    Turn signal issue
    So my dash computer is telling me that my passenger rear turn signal is out, but it’s blinking fine. And, the green arrow on the dash is flashing rapidly, usually and indication that a bulb is out. This ever happen to anyone before?
  12. SuperUnknownSG
    Headlight Issues
    So I installed so very beautiful Taillights on my 2018 ram 1500. I had to use a harness that stole some signals off of the 7 pin trailer connector. I notice now that my timing from the front signals to the rear signals are slightly off. Is there anyway to fix this? Can I change the timing somehow?
  13. _TopGear
    Turn signal light out, LED Tail lights
    I just got my new (to me) 2013 Laramie Longhorn. I'm getting a "left turn signal light out" message and it looks like intermittently my rear turn signal is not lighting up in one area of the tail light, (and blinking fast) I cant find anywhere what type of bulbs the tail lights need other than...
  14. Jack317
    No turn signals or hazards
    2001 dodge ram 2500 here, got home from work last night and parked it with no issues, went to leave today and had no turn signals/hazards. I replaced the flasher relay and replaced the two regular fuses with no luck. Is there anything else that could be causing this besides the turn signal...
  15. Underground Lighting
    Hyper Flash Turn signal Solution Plug and Play Resistors
    Hi Everyone, We have had a lot of customers asking us for a plug and play solution for hyper flash. Those of you that may not know what hyper flash is, it's when you change your turn single bulb to led and your light flashes fast and your dash indicator flashes fast as well. There was always a...
  16. A
    08 - crazy winkers
    So my 2008 ram's turns signals blinks too fast. Where I can start looking for the problem? The light bulbs have been all changed to led but it didn't make any difference when I put there resistor or relay. It also didn't make any difference when I changed all bulbs to the normal ones. 2008...
