Non powerfolding to powerfolding mirrors help
Buckeyedavey2323
I have a 2014 express and got some 2018 powerfolding mirrors that has the puddle lights and powerfold option I want to switch too I got them painted to match the truck and already got the different switch for inside do I just have to take it to the dealer or what do I need to do
firemedic10584
Central Fl
use the search function and you'll find this topic covered multiple times. But you'll need the door modules with the power fold function in them, then you'll have to have your dealer add the powerfold sales code and reflash your computer.
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
Not to thread jack, but can you use the powered mirrors in the same manner as the manual mirrors without the power fold module?
Will the powered mirrors fold manually or will there be issues and possibly breaking the power fold motor?
kad
Hudson Valley, NY
5.7L HEMI
Mine will fold manually, BUT, you need to unfold them manually afterwards to re-engage the mechanism.
-K
GIJoe2010
Killeen, TX
What I also meant to say is, if some cheap ******* (like me) bought a set of powered mirrors and didn’t buy the power module one could just fold and unfold the power mirrors just like the lower tier non-power mirrors?
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Yes, you can still manually fold/unfold them.
Here's the modules & CC switch that work for a 13/14 truck (maybe more) that I used on my previous 13 Ram as a reference for you.
Note: Dealer will likely be unable to activate the power fold option for you (trim level determines if it shows in their system) but you never know. If so you will need to an OBDgenie to activate it.
(Pwr Fold, Heated, AutoDim w/o color, w/puddle/signal)
(R) Pass Mirror: 68231240AD (GuK) Dr Module: 68225102AC
(L) Drvr Mirror: 68231241AI (GuK) Dr Module: 68225103AC
13/14 CC Door Switch: 68110867AB
Related Sales Codes:
GN5P RR View Auto Dim Mirror w/Microphone
GNZP Auto Dim Exterior Mirror
GUKP Power Heated Mirrors, Fold-Away (not needed)
LEBP Ext. Mirrors w/Supplemental Signals
LECP Exterior Mirrors Courtesy Lamps
LERP Power-Folding Mirrors
LEUP Auto Dim Exterior Passenger Mirror
GIJoe2010
Killeen, TX
Cool thanks.
I really like the puddle/courtesy lights and supplemental signals in the upper tier mirrors. Powerfold (motor) isn’t really a big deal as it’s something that can and may break and need to be replaced.
78Staff
US Navy Veteran
NE Florida
@Mpgrimm2 and all...
Well I finally found some power fold mirrors for a decent price. They aren't "full" memory, but have everything else including Auto Dim feature. Came off a 2017 Rebel. Will roll with these, if I ever come across a full memory set for a decent price I'll just upgrade later. Now just need to order the modules and switch.
Haven't found anything newer part no wise for the switch and modules for a 2016 than shown above, so going to run with those.
Mpgrimm2
SC
5.7L
Just double check that switch PN with forum vendor allmoparParts.com (Benny) to make sure it works for your truck. They changed the connector style at some point (1 connector vs 2) and I'm not sure what year that occurred.
M² Mods.
78Staff
US Navy Veteran
NE Florida
M² Mods.
Hmm this is a good point, pretty much all the listings have been showing that part number with 2 connectors good up through 2016, but my 2016 has the single connector plug, not 2. More research required :(.
78Staff
US Navy Veteran
NE Florida
Yeah I had to get '13 or up due to temp sensor, but at least the ones I got are like new :). He swapped to tow mirrors right away apparently.
78Staff
US Navy Veteran
NE Florida
I think, it might be this one... single harness connection, 2017 and up it appears. Maybe I just have a late 2016 build. I've pm'd Benny to confirm though.
56046826AE
78Staff
US Navy Veteran
NE Florida
Forgot to update, Benny says that switch is good to go, so I just must have a late 2016. Anyway, Chrome Power Folds are sitting on my workbench, switch and modules arrive tomorrow, so should have this all wrapped up by tomorrow evening hopefully :).
WTM75
Upstate NY
3.6 Pentastar
Mine don't arrive until Tuesday. But I still have to order my modules and switch. :(
