o2 Sensor
joepizuro
Magnum v10
I was told there are two kinds of o2 sensors. One that is midstream and a downstream one?
My question is should mine be replaced with an o2 Simulator on my 95 Ram 1500 or not if I take the cat off. I don't care about the check engine light but I don't want too much or not enough fuel getting added to the mixture if I redo my exhaust without a Cat..
I'm sure mine's only got one lol. Never did much work on exhausts.
ATXHEMI
Round Rock Tx
The o2 sensor before the cat reads afr. The downstream o2 makes sure the cat works/is there. As long as you leave the front o2 you will be fine.
J
joepizuro
Magnum v10
95 only has 1 apparently, looks like it goes directly into the cat?
