Walker Clark
Hi fella's
I just finished installing door speakers on my 14' (6spkr). Would appreciate any advice, I am baffled as to what has happened to my front channels low end freq response. I'll try to explain this in the plainest way possible.
Order of Operations:
Everything is back together for tonight, but damn I'm perplexed. Thanks for reading thru - hope I can get to the bottom of this. Should have left door speakers stock, it didn't sound that bad.
Walker
- Installed new front passenger door speaker (Pioneer TS-G690) with metra harness from Crutchfield.
- Turn on the radio to test new speaker before putting the door back together.
- Instantly notice new speaker has zero bass.
- Install OEM speaker back, also has zero bass.
- While playing music, pan between each corner. Confirm front right has NO bass. All other doors still producing reasonable bass.
- Decide front right channel could have an issue (junkyard RA2 radio recently installed).
- Proceed to install all of the Pioneer TS-G690 into the remaining doors.
- Test finished product. What do you know, the driver's side has NO bass response now.
- Very confused. It seems after unplugging OEM speakers the low freq has disappeared from both front channels. PLugging OEM speaker back in does not seem to fix problem. Overall system sounds okay, no distortion etc.....but wth?
Walker
