OEM Aux Switch Dimensions
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
I'm here from the 3rd gen side to ask a favor. Could any of you guys with the OEM aux switch bank get the width and height of it for me? Since there is zero aux switch bank options for the 3rd gens that I remotely like, I thought I'd give the 4th gen switch a look.
From the pictures I see it looks like its about the same width as my lower radio bezel cubby, and the mounts look very similar as well. Just from eyeballing it it looks like it is a bit taller though, so would probably have to do some cutting
tron67j
Maryland
Let me know if the pictures work. Note the corners are rounded.
Fishstickz
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
Those worked great, thank ya. Looks like my opening is about 1/2 inch wider and just about 1/16th shorter. I was wondering how to deal with those rounded corners since mine are squared off. Since there would be about a quarter of an inch gap on each side, i could fab up some sort of filler to deal with the openings and the corners. I planned on using the big opening on the bottom of my radio bezel
I may get some measurements on the upper opening since by eyeballing it may be a tad better fit
Thanks again
