Oem projectors
Mattyd926
Nj
EcoDiesel
what is the best route if I was going to go with oem projectors , besides from the dealer . Are the aftermarket versions I’ve seen any good ? I’m not opposed to buying a stock projector and building a pair . Your thoughts ?
OC455
Central NY
Aftermarkets would be cheaper by a bit. Are you looking to go HID with the projectors?
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
I’d check local junk yards for them! HID is king in OEM projectors!
Killingsworth
Parkersburg, WV
I've been wanting to do this as well. Hard to find the chrome projectors. Spyder sells them on Amazon. Dont know how well they are made. Would like to stay under 600 after the adapter purchase. Any suggestions for online options?
Mattyd926
Mattyd926
Nj
EcoDiesel
I was set on led bulbs but after a little research I’m most likely going hid. I want to put in a drl board for white / amber if I have to get a rgb one I will to make the blinker sequential like . A halo kit as well . Pixel looks quality bug the oracle performs nice but comes with zip ties to install wtf is that
OC455
Central NY
Retroshop or The Retrofit Source for DRL boards and halos.
Gregdad
Fort St. John BC, Canada
I bought TYC chrome projectors from Rock Auto and couldn’t be happier. Way more light output even with halogens thanks to their clear low beam projector lens.
I tried led’s in my stock black projectors and it sucked bad.
Light output was scattered, not focused at all.
I might try hid’s in my TYC’s but I really don’t like the idea of putting holes in the dust caps.
