OEM Remote start
Greg Motz
Pittsburgh, PA
i want to install a factory remote start if i install it will i be able to start with the key the tuck so i can get it to the dealer for programming
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Not sure, although I'd look into getting AlfaOBD and doing it yourself. You'll likely spend less then the dealership charges and be able to do more modifications should you need to.
kad
Hudson Valley, NY
5.7L HEMI
The instruction manual tells you to do all the work except pluging in the new RF Hub, then drive it to the dealer like that for them to program and do the final hookup. Although you'll spend a few hundred less if you get AlphaOBD and do it yourself. :)
-K
