Off Road Lights in Mirror
Harry O
Valencia, CA
Howdy.
Has anyone stuffed a LED off road spot or flood light in a side mirror assembly? I've been looking around for photos of disassembled mirrors to see if a flush mount cube light will fit in the mirror body or arm for a non-tow mirror.
I'm looking to go more stealth than a A pillar/hood/brow mount for some lights. I have the factory tow hooks so putting a bar LED there wont work.
Ideas/suggestions?
sbarron
Wasilla, Alaska
You may possibly make those fir, but unless you're looking for just a small amount of area lighting you'll be disappointed in the output, those small lights just aren't meant for driving. I have 4 of the Rigid A series frame mounted under my truck and as yo can see from the video, it doesn't exactly look like a sunrise under there...
You probably have grill shutters so behind the grill likely isn't a solution.
MarshRam
2014 SLT 4x4, 2012 ST
Subscribed. I have had the thought of mounting some cubes with a swivel on the top of the arms. It should be doable since you just need room to mount the screw and run the wires through it.
