Off Road package
ksn240
I think that's few and far in between in my area. They wanted to charge 7500 dollars to put a leveling kit on my original truck
That is insane. I did it in my dad's shop in about 2 1/2 hours. For $7500 you could take it somewhere and get a full lift, wheels and tires.
The_Chemist
Swatara Township, Pennsylvania
The off road package has 3.92 gears, hill descent control, electronic locker, different shocks and skid plates. Adding it after the fact would be quite expensive I would think.
That's why I added it at the time I ordered my vehicle .
Will the heavy duty shocks from the off road package also alter the ride quality? Adding firmness or a stiffer ride?
troutspinner
Gilbertsville, Pa
2019 Big Horn Crew Cab
I don’t personally think so. I drove a few different models with and without and I did not notice a difference.
19Streak
Ontario
I was more thinking the height difference for the off road package. I ordered my truck with 3.92 and e locker not that my truck will be going off road very often
troutspinner
Gilbertsville, Pa
You get 1” extra height with the ORP. You can get 2” with the factory lift or more with aftermarket.
ksn240
The factory lift only works with non air ride trucks. OP has the air suspension. He will get the extra 1" with the offroad package though because they program the air suspension differently.
soapy
soapy
Northwest
6.4 hemi
I can say that my 2019 with the off road package rides better than my 2015 did and it did not have any type of off road package.
justice
Arlington, Tx
I would really like to know how the 1500 rides on highway with the off road package.
I ordered a 2019 Laramie Longhorn with air suspension and the off road package.
As you stated, the dealer didn't have one with the off road package, so I ordered it un-test driven.
I had previously ordered a 2018 Jeep Wrangler Rubicon, then changed my mind and ordered a 2019 Ram. Of course the Longhorn is no Rubicon, but I felt I'd get the best of both worlds
I'm really hoping that the off road package does not destroy the awesome highway ride or add a bunch of tire noise with the all terrain tires.
I am getting ready to order a limited with the off road package and have the same questions ... did you get your truck yet? Any update appreciated!
runamuck
dfw
6.7 dsl
I have had my 2019 laramie 4x4 ccsb ORP with sport pkg. since the end of august. I think it rides great. I put the helwig swaybar on and still rides great. I came from a 2017 gmc sierra 4x4 ccsb and I think my ram 1500 handles better and rides a little smoother.
Alangsam
USA
What is the benefit of the Helwig sway bar?
runamuck
dfw
6.7 dsl
the helwig is just one of the after market sway bars available to replace the stock one with a stiffer one that reduces lean on turns and just generally stiffens up the rear end a little. I was getting a little shimmy in the back when towing my travel trailer. I think it is a factor of the ram having coil springs instead of leaf.
Alangsam
USA
Did it have any effect on ride quality when not towing?
runamuck
dfw
6.7 dsl
not too much. without the trailer, the truck seems pretty tight and responsive for a truck but not a harsh ride at all.
Mpmitch1
madison
v8
THE ORP rides awesome, in my opinion it rides better than the mopar lift with fox
kevinc32
Waterford, Pa
Does anyone know if you can add an aftermarket lift to the truck if it already has the factory 1" installed?
brian42
San Diego, CA
There are plenty of options. Just cruise through other threads in this Lifted forum as there are many options.
Depending on the components of the lift kit you may or may not have the same height results since you are starting 1" higher than the stock suspension.
JustinRam1500
