Oil Catch Can Results
MK12RAM
Georgia
Do you know of a link or have a pdf file of how to install one of these on a 2012 Ram 5.7L?
omega88
Where does a guy order a catch can with all the required fittings for install?? Thanks guys. I don't want that crap going back into my engine!
Musclemckeester
Houston, TX
n/a
n/a
Check with Matt @ Moe's Performance (a vendor here). I believe he can get the catch cans.
audio1der
Airdrie, Alberta
Is there any possibility the oil is required for lubrication of the internals?
I DO see the benefits, but also wonder about any long-term consequences.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Only thing it is doing is clogging up your throttle body and pumping hot oil back into your intake. This hurts performance and requires added maintenance.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I made my catch can with compressor separator from home depot works well and was under 30 bucks. You can't see much of it so need for fancy bullet unless you have the cash.
$miley
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
added this to my Christmas list :)
audio1der
Airdrie, Alberta
$miley
I'd buy one right this second if there was a non-bling, functional unit available. I don't get the whole billet thing for WAY under the hood accessories, and won't pay for it.
Edgethis
Bluefield, WV
I agree and wish that some companies would make a generic version of these. I see no reason to spend $150+ for a oil catch can when you can make one for under $30 as Smiley has done.
hemipwrd
Rowlett, TX
I read a lot about these and honestly thought it was just a hoax. Then I saw a ton of guys that had them so I had to give it a shot. After I saw mine was a 1/3 full after only about 1,000 miles I was a true believer. Its a must have no matter the cost!
paulycoppola5
Schenectady, NY
smiley can you give us a list of stuff you bought and a brief description of your install??
pics not really needed for me but I'd like to throw one on my truck, on the cheap, while i do my HID's this weekend.
hemipwrd
Rowlett, TX
I got mine off ebay, it was $110 shipped. Real easy install, only issue was getting the supplied hoses over the existing fittings. A little boiled water helped alot. Beyond that it was a 15 minute install. Its not a flashy BT catch can but it looks the same without the engraving on the top, does the same thing but for less money. Seller on ebay was uprproducts.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
For anyone interested in the Billet Tech catch can, I have 8 in stock right now. Satin finish, brass fittings, and PCV hoses included. They are $134.99 with free shipping.
paulycoppola5
Schenectady, NY
UPR makes great stuff!!
I am probably going to just pickup a catch can then setup my own deal. Not knocking the BT setup or any other kit for that matter, to each his own, however I have faith I could put together a catch can setup that functions as well as any kit and just doesnt look as pretty for under $50
bloombloom88
Plano, Texas
Dodge didnt install these from the factory for the same reason that they didnt delete the DPF and EGR on the diesels. Those parts cause nothing but trouble for the guys that dont delete them themselves, but the govt. forced them to have them. A catch can should be 1 of the first mods for all 09-up Rams.
Even on the 4.7? I heard it was mainly the hemi that had this problem?
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons make you fat...
Alfonsio
2010 Big Horn Quad Cab 4x4
Smiley,
I looked in Home Depot and didn't find anything that would work. Can you supply a picture?
Thanks,
Souths1der
SW Suburbs of Chicago
2022 1500 Big Horn Crew
Check out this thread:
http://www.ramforum.com/f44/lowes_catch_can_install-30402/
Here is what he used (Not my truck)
I used a Kobalt filter like that on my air compressor once (but it was different than the one in the picture). The fittings were plastic and broke pretty easily. I can't tell if the fittings on the one in the picture are plastic though. If they're metal, I suppose it would be OK. But if they are plastic, I wouldn't trust it.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Smiley,
Thanks,
Look in the compressor, air tool isle. I used a Huskey for a while but didn't like the plastic bottle so close to the manifold.
1882
It baffles me why there are not more Moroso catch cans on this forum. It's only about $15 more then the BT and the mounting location is much more convenient and it has a drain valve. Seems to me to be a vastly superior design but highly underutilized. Just my .02
Arturo Rojas
