PaleFlyer
The PCV link routes some air back from the exhaust side into the intake again (From my understanding), and the Hemi, like a lot of modern engines has a little too much "slop" to make machining cheaper between the pistons and the walls, which allows a small amount of oil/unit time to "blow by", and come out the exhaust side. My 89k '18 gets about a half cup in the can ~4k miles. My thinking is, $150 to keep the **** out of the intake, means less other **** will get caught by the sticky oil, and slow/block the intake ports. So cleaner combustion, and more power, as well as just keeping the engine in a little better shape longer.Thinking about installing an oil catch pan ? My Ram is 2015 with 141,000 original miles and have never seen oil seepage anywhere ? Dose it happen to the HEMI's latter on ? I have always used synthetic Amzoil that at 6,000 miles is as clean as new.
Could someone tell me what I need to do so it wouldn't start leaking oil ?
It isn't something you will "see". If you are SEEING the oil seeping out, the issue is NOT fixed by the catch can. It's a much bigger issue.
