Timothy Bierley
I the 24 years I worked for Ford Motor as a Diesel Tech. We use to have engine noise on cold starts and low oil pressure. What we found that the problem sometimes was the oil filter (STP). I have been reading the cold engine noise on 5.7 engines because some oil filter do not a bypass valve. Ford FL820 and FL500 have a bypass at the base. So I am going to try a FL500 on my 2012 Ram. What are you all thoughts.
