oil on power steering unit
Roger33917
Fort Myers, Florida
While laying under my truck 2014 Ram 1500 5.7 Hemi 2 wheel drive yesterday I noticed oil drip coming off my electric power steering unit where would the possible cause of this come from where should I start looking first it just hit 47000 miles?
pacofortacos
Is it right below the oil filter?
On my 4X4 the steering sits right below the oil filter, needless to say it gets some oil on it with every oil change.
R
Roger33917
Fort Myers, Florida
I'll definitely check that will know tomorrow I'm going to get up under there again with a light see what's going on thanks for mentioning that
Bigpaul13
If you got oil changed recently, it's probably from them removing the filter like Paco said. I still spill some oil when doing a change. If you're crawling back under, double check that the filter is tight and give everything a wipe down. If there's oil there again and a few days, you gotta do some more looking.
jws123
nj
As long as the area is not soaked or you see oil shooting out you are probably fine.
Steve58
