Oil Pressure?
Firefighter613
It seems as if the oil pressure gauge drops at idle, when I put it in gear when i've driven it for awhile. (Happened since Ive gotten Cold Air Intake), only see it when i drop below 500rpm.
no difference in performance
What could this be? Should I worry?
jsl6v8
Virginia Beach for the moment
2013 Ram 1500 HFE RCSB
3.6L V6 And proud.
Hmm thats curious mine does the same thing, I just bought it recently, kinda just assumed that was normal. Hopefully someone will pipe up that knows something :)
Merc225hp
NA
truck
gas
I need to know what it is dropping to and at what temp IE cold or at opt temp.
Min oil psi as per the fsm get this is 10psi at idle warm, I could not live with that. Oil psi does vary with rpm's.
Post up your numbers.
