Oracle LED H13s
15RamEXP
I received new headlight / taillights as a gift.
09-16 Dodge RAM 1500 2500 3500 Black-Out Headlights + Dark Smoke LED Tail Light | eBay
I had quad lights, emailed the vendor thinking they were the wrong ones. They provided the below link.
http://d3d71ba2asa5oz.cloudfront.net/33000904/images/2006 ram h13.jpg
So I got Oracle Lighting 5236-001 (H13) LEDs. They shut off after 5 seconds. Same issue I had when I tried to do HIDs.
Anyone else out there do this swap? I went got the high end halogen bulbs, but the H13 halogen bulbs did not fit. Ideas??
You'll probably need two CANbus error correctors for each LED bulb in the headlight housing, unless you can find a dual error corrector. Diode​ Dynamics makes an error corrector that works with '15 and newer Rams(you'll need four).
Your probably going to catch an earful about putting HIDs in a reflector housing.
If you have problems with the tails theretroshop makes a dual adapter for the LED tails
15RamEXP
Thanks for the info, will check it out. I did not put HIDs in. The LED tail lights are working perfect.
What I typed above sounds a bit confusing about the number of correctors. If the LED does both High and Low beams(it will have three wires at the plug), you'll most likely need two correctors for each side(four total).
15RamEXP
Just connect them in line? So wire harness, corrector, corrector, LED?
Each corrector needs to be wired for the High and Low beams individually. One wire on each corrector will be wired together on the common wire going to the headlight LED bulb. Polarity is important.
OnSale
5th Gen Crew
Philadelphia, Pa
Here ya go. This is exactly what you need and is plug and play and only $10.
http://www.opt-7.com/tipm-resistor/
Select h13 and your all set. The resistors are already wired to the highs and lows. These are made for Canbus vehicles with TIPM computers. They made these specifically for our dodge rams.
• 2012 Ram 1500 RCSB Hemi • 22" SRT-10 Wheels Plastidipped Black w/ Bridgestone Tires • Smoked Taillights • Custom Quad Headlights • Opt-7 FluxBeam-X 6000k LED Lows • MicTuning 6000k LED Fogs • K&N 63 Series CAI • Flowmasters Muffler • Line-X Bed • OEM Black Badges All Around • 20% Tint All Around • Lund Tri-Fold Tonneau + plenty more coming soon...
