Outside thermometer issue
Your moms fav
Vancouver, WA
6.7L
I have a 2014 2500 Laramie. I plugged my block heater in, and now my outside temp is reading around 100. It’s been in the 20’s… I thought maybe it would re set after driving, but it’s been like that for around four days. Anyone know how to fix it?
kad
Hudson Valley, NY
5.7L HEMI
The exterior temp sensor on a '14 1500 is in the driver's mirror, it was near the passenger headlight on 2013s and older. I'm not sure if the 2500 would be a year behind or not, they are for some things. But I believe I've seen the 100 reading when the sensor became unplugged. I'd start with checking the connections. You should be able to see if it's in the mirror, it will be a small indent with a nib in the middle of it on the bottom edge. If you need I can take a picture of the location tomorrow when it's light out.
-K
joshhhh
