Overall height with 35s - Garage
joesstripclub
Kansas City, MO
2021 2500 PW
My stock tires are showing a good amount of wear and I'd like to upgrade to 35s when I get new tires. Anyone know what the overall height ends up with a jump in tire size? I'm lucky enough that my truck fits in the garage which is a standard 7' door, so ideally I'd like that to continue. If my napkin math is right it should only gain about an inch overall?
White six four
Wisconsin
Not a powerwagon but my truck 2500 with thuren 3" springs in the front and icon 2" rear springs and my old 295 70 18 tires measured 6' 11". Used a 4 foot level across the back of the roof. It gets parked in the pole shed. We also have 7' doors on our attached garage but I've never tried getting it in.
joesstripclub
joesstripclub
Kansas City, MO
2021 2500 PW
Good thought on the 4' level. I was going to try to measure with the truck halfway in the garage sometime but that sounds a lot easier. The shark fin antenna is my high point, I'm within a couple inches from what I can see from the driver's side.
White six four
Wisconsin
It helps to have 2 people if you do the level like I did. Most 35's usually measure out to be 33.5"-34" once on the truck. Which you may already know, but might help with the math if you didn't.
buckeyexx
Ohio
2016 Power Wagon
I have a 7 ft door and my power wagon fit with about 2-3” to spare. Mine sat on 35’s and had Thuren front level kit and 1” block in rear. You should be fine
Lsujker
Baton Rouge
For reference. I have a 2500 tradesman on 285/75r18 toyos. Close to a true 35. No lift and my antenna hits the 7’ parking garage thingy above. Any taller and would hit. Being a wagon is about 2” taller, will be very close.
olyelr
Kewadin MI
A lot depends on the slant/setup of the driveway, as well as how the trim/jam is setup on the door. And just because you have a “7’ door” dosnt always mean you have a full 7’ of clearance.
My wagon has 1.5” up front and 35’s. I can fit in my parents garage which is a 7’ door, but i couldnt fit under the 7’ door in my rental house.
It should fit, but will certainly be close if it does.
But just keep in mind, if you measure the height of the truck on flat/level ground and it is less than the door opening, it may still not fit.
I would pull the truck half way in the garage and stop when it is closest to rubbing, then measure what you have left. If there is anything over an inch and a half of room, you should be good with adding 35’s.
joesstripclub
joesstripclub
Kansas City, MO
2021 2500 PW
My old office's parking garage was like 6'-9" or something, google said I should have about an inch clearance based on the listed height of the truck. I could clear one of the crossbars but clipped the one at the other entrance, so I had to stay to one end of the parking garage. It was still really tight everywhere though.
joesstripclub
joesstripclub
Kansas City, MO
2021 2500 PW
Great info, thanks. The header or trim above my garage is sagging a bit so I've lost a fraction of an inch I'm sure. Sounds like with stock suspension and 35s I should be ok.
2016 2500
Air Force
I have a 2500 with 35 tires it fits, but barely I backed it in, as I was doing some work and did not need to close the door. but my driveway is sloped it might be the difference. IMG_20250407_155842.jpg
metalchewy
Las Vegas
2010 TRX4
4.7L
From 285/70R17s to 315/70 R17s, my front and back diff measurements to the ground went up just over 3/4".
62Blazer
Midwest
On paper you should gain around 1" of height. Just keep in mind that different brands and styles of tires have different true heights, so that could change a little. The best thing to do is check your existing clearance. Pull the truck into the garage and see where the closest point is (as you said, probably the little shark fin) and see how much clearance you have. I would say you would want at least 1.5" of current clearance and that would still be tight.
olyelr
Kewadin MI
A lot of that depends on what the tires are aired up to. But yes…going from a roughly “33” to a roughly “35” will only gain you an inch-ish of ground clearance.
Bruinsfan
South Berwick, Maine
2017 2500 with a 2.5" spring lift and 295/70/18's and I'm sitting right at 6'9" ish, only thing that hits is the plow light when I forget to take it off before pulling in
StateOfMind
Orange County CA
Before you shoehorn it into the garage, make sure you are taking in to account cab lights or siriusxm antenna. Can't tell you how many yahoo at work take a work truck in the parking structure and tear off the shark fin
Schotzy
USA
2022 Power Wagon
Hemi 6.4L
I have a 22 PW and Im running BFG KO2. Size 35x12.5R17 (stock rims) and im about 1 inch taller. Hope that helps yea. Oh and my speedo is off 5MPH as well.
