MO_Scout
It’s a 2007 1500 4door 4wd with a 5.7 Hemi and nearly 160k miles. Had some grinding with going easy on the gas at 35-40, then when I hit 60 the check engine light came on and I lost acceleration. Restarted the engine, and it drove fine to get the code run. It pulled a P0016, so I replaced the camshaft and crankshaft position sensors, reset the ECM and fired it back up. Check engine came on again and I am having the same problems. Then driving the hills on some backroads, I had it to the floor and couldn’t get over 30. Currently, at 60 I’m running about 3k rpm. I’ll slow from 65-55 in about 2 secs if I let off the gas, then it hesitated to accelerate, but it seems to drive normal at 45 or below. Any ideas?
Edit: forgot to mention that 4 wheel won’t engage and hasn’t been since before this issue, and my ABS light comes on intermittently. Not sure if those are related, but thought I’d mention it.
