P0252
brian.neidlinger
my truck is throwing this code, anyone got any ideas? it will turn over but it wont start, i just put a new injection pump and airdog 100 on it less than two months ago. any help would be great.
Horns
Waterloo, Iowa
01 Chevy 3500HD
12v Cummins
Well since you just put a new injection pump on and an airdog I would try taking the airdog off first and seeing if it runs. If it doesn't then it's probably the injection pump, if it does then you know it's the airdog.
ramhunter9
P-Star Jeep Wrangler
first off what truck are we talking about hear ? what motor ect . info would help out , but if its all new stuff you put on i would make sure its all intalled correctly . then re set your PCM to clear the code .
according to it this is your code ... P0252 Fuel Inj Pump Fuel Valve Stuck
ramhunter9
i just sticked in each gen section under the tec forum all trouble codes for your specific gen .
Fatboy1989
