P1521 when it rains?
acolic
Hamilton
Hi
I’ve started to get a P1521 only when it rains. After things dry up the code goes away.
Anything obvious I should look at?
Thanks
Alex
Fast69Mopar
When was the last time you changed the oil? Did you use the correct viscosity as in 5W/20? This code can set due to incorrect oil viscosity. I also remember at one time there was a flash update available for the PCM because of this issue.
A
acolic
Hamilton
Hi
I changed it in May and I used Valvoline Max Life 5W 20.
So right oil and I only get the code when it rains.
