P21B2 code keeps coming up.
Meg M
P21B2 code keeps coming up. Dealer never fixed it. It comes back within 20 miles after deleting. What are your ideas for possible reasons?
Burla
2010 Hemi Reg Cab 4x4
You have an aftermarket filter? Check tdr and cummins forums, they just have a lot more cummins to add to the info you get on ram forum. If it is a 2012, you are in the wrong generation as well. Generally a nothing code, if that is the only code I personally would ignore it, or change my air intake unless you have oem, then I wouldnt touch it. Keep running the codes though, if you get another related code you should take action.
joshhhh
