Painted tow mirrors
DohCanadian
Saskatchewan, Canada
Just wondering if anyone has some pictures of their painted tow mirrors? Thinking of color matching mine but wanted to see how they look first.
And what kind of prep and procedure did it take.
Thanks
apepe0738
Peoria, Arizona
2012 Ram 2500 Crew Cab 4x4
On my mirror caps, I started by cleaning them thoroughly in the kitchen sink. Between the dawn soap and simple green it got clean. Afterwards I dried and primered them. Then I sanded the primer down with 400 grit sandpaper, and cleaned it all up with alcohol and a rag. Then I sprayed ~5-6 coats of paint, about ~15-20 minutes between coats. I let them sit afterwards for a few hours and then clear-coated them. They were fully cured in about a week. Best advice is to take your time and DO NOT RUSH. Came out great.
I got the spray-bombs mixed from ebay, the listing I used is not there anymore but you may be able to find someone on there still. The cans that came were from Sherwin Williams so you could probably go to one of their stores and get one mixed.
A little pricey but the color was exact and you get a standard 12oz. can (I think the ones from the dealer are smaller). Between my mirror caps and painting my antenna base, I went through about 1 can.
Mine were not tow mirrors, but the process should be relatively the same. I would suggest sanding down any chrome as a first step...
DohCanadian
DohCanadian
Thanks for the in depth write up! Yeah my tow mirrors have no chrome so I don't have to worry about that.
apepe0738
Peoria, Arizona
You may want to try sanding down the textured plastic first. I didn't and the texture carried through. It doesn't look bad but it does take away from the gleam of the clear coat. If I had to change anything about what I did, it would be that. Best advise I was given, if you can see any blemishes made by the sand paper, i.e. scratches from using too abrasive of grain, make sure you sand it out with the higher grain to make it smooth, the paint will amplify it. Hope this helps...
alphaprojects
