Tim C
Hi All,
Hoping to get some direction on diagnosing a battery drain issue I'm having.
For reference, the reading directly between the positive and negative lead is 12.27
I've disconnected the negative lead and hooked a multimeter up between the negative lead and the negative post. I've disconnected the hood light.
Reading starts and stays as 12.18 amps.
I've pulled all the fuses from the fuse panel in the engine compartment (as far as I can see, there is no fuse panel in the passenger compartment.) No changes in the reading.
I did notice that if I open then close the door hard, the reading drops to around 11.68 then slowly climbs back up to 12.18. If I close the door lightly, there is no drop.
Given this, I'm thinking there is a short somewhere (shaking of the truck by closing the door momentarily breaks the short).
Given all this, any suggestions on how I continue to investigate the cause of the drain?
Thanks in advance!
Thanks in advance!
