Park brake sensor for DVD
MB1500SPRT
Manitoba, Canada
What do I gotta do to get my in-dash DVD working while the vehicle isn't in park.
Thanks guys
jbmobbs
murfreesboro, tennessee
pull the plastic kick guard off of your parking brake and unplug the sensor that might help
jbmobbs
true.....go get a wiring diagram and cut the wire coming from the back of the dvd player to the sensor.......i dont know much on it this is jut my 2 cents
300MAG
You need a lock pic, it reads the speed data over the can bus lines, dont start hacking parking brake wires. i got my v.4 on ebay for 175 shipped last year. This will also also to program that nav while driving.
(S.M.R) 101
Corning, NY
2013 Sport
5.7L HEMI
the Lock pick is really the only way to go with this matter.. like dave said it goes off when the truck is moving and does read speed. If you have the GPS with your dvd unit the lock pick will give you the "Full" functions of your gps as well while driving.
quietpeen
2021 TRX
Hellcat
def. lock pick
Musclemckeester
Houston, TX
n/a
n/a
My brother in law has a 2011 and he was talking about trying to "re-wire" it to work. The biggest problem with that I see is that if you ever have a problem with the radio and need to get a replacement, you may be out of luck if the dealer sees you've hacked up the wiring.
With the lockpick, if anything with the radio goes wrong, all I have to do is unplug it and remove it. That's the nice thing about plug and play.
Steve58
