Parts needed for a larger fuel tank conversion
Gero
Ontario
I have the pathetic 26g and would like to swap to the 32g. Does anyone know what other parts are needed other than the tank? The larger tanks go for about 140$ around here.
Brandon-w
Yukon
2015 Ram 1500
Are the straps the same?
2012Lamarie
Not that most would care but would you need to program the pc to tell it you have the larger tank so it estimates your fuel range correctly. Also maybe a different sending unit?
Sent from my SM-G965U using Tapatalk
HvyDuty
Perrysburg, OH
5.7L
For 2013 to 2017 1500's its plug and play and easier if you get the pump with the tank, gas vs. gas of course.
Not sure about older. I do know that for 2018+ Ram changed the physical tubing/emissions config. I tried to use a 2017 32 gal tank (newest I could find at the time) on my 2018 and even the pump had a different number of tubes/emissions crap. I was pretty pissed when I had the 26 gal tank out and realized it would not work...lol
Gero
Gero
Ontario
You wanna sell it?
ameer73
