Passenger headlight
Chuppyh
Alabama
So my Passenger headlight stopped working low beam and highbeam so I put a new bulb in and still no luck I check with test light I have 12v on both sides of low beam bulb thinking can’t be right you got to have a hot & ground I have 2 white & 1 black so I connected the black to ground the light came on but the wire would get hot I don’t understand any help will be appreciate.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I saw a video a while ago, it may or may not answer your question
2009 & 2011 headlights may be the same, both of them are early Gen 4 series
& this one on proper wiring repair, it is a follow up on the other video
