PCM question
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
For those who have replaced their PCM's. Can PCM's from the the same model and year be swapped in and out without being flashed to the same VIN? I want to have a backup PCM for a custom flashed PCM and am wondering if I need to have the junkyard backup flashed or can I just plug it in to use.
Thanks,
heminit
LA (Levy Area) Central AR
I think as long as there is a VIN in there it doesn't matter. That's my understanding, but I come from the days of bigger carbs and turning the distributors.
Redtruck-VA
Redtruck-VA
Virginia
Brother I hear you, I am the the old guy on the forum....
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
yeah, you will need it flashed for your truck, needs to contain your vin, and your mileage. a dealer can do it, but itll cost a pretty penny. most mechanics can do it for less i would imagine. i bought one from solopcms online, gave them my vin and mileage, they sent it off already flashed and ready to go.
Redtruck-VA
Redtruck-VA
Virginia
I went a head and bought the junkyard pcm and we will know if it'll work or not. My local dealer is completely incompetent. I wouldn't trust them to air the tires.
RubberFrog
If you don't get it vin flashed, it won't communicate with your cluster and you'll be SOL.
Redtruck-VA
Redtruck-VA
Virginia
Well, I guess I'll need to get the junk yard PCM reflashed with my VIN. Switching back and forth there will be a mileage discrepancy, Hopefully that won't be a problem.
Thanks,
RubberFrog
That will be a problem.
Is it just a back up in case your custom pcm gets fried? You could get a cluster and a pcm both flashed and then you wouldn't have an issue. More **** control from chrysler....
Redtruck-VA
Redtruck-VA
Virginia
I know folks like Solo wants the VIN and mileage for the PCM flash, and I thought I read someplace the mileage was also stored in the CCM. But didn't know the PCM wouldn't update the CCM. So what you are saying I need to match the CCM with PCM. I have never heard reflashing a CCM for a match. Not sure what I'm going to do as my dealer can't get anything right. Any ideas?
RubberFrog
Clusters go out all the time and get reflashed. I don't even think it needs to be the dealer that flashes it.
Redtruck-VA
Redtruck-VA
Virginia
i guess I'll just keep it in standby and flash it when and if I need it. Nothing is easy it seems.
