pedal commander
gilleydog
florence az
2017 ram larami
received a pedal commander from Moes performance and it came in a 6x3 plastic box no cardboard presentation box ? is this the sign of being refurbished ? ordered one from amazon and it came the same way I sent it back please advise thanks
TJames
I received my pedal commander last week from Nick. Came in the same style packaging. I was surprised as well but it looks and functions like brand new. Im thinking that pedal commander has just changed their packaging.
mboymopar
MOPAR
West Michigan
2025 Big Horn Sport
3.6L Pen
Received my PC the same way from Nick.
I see this same packaging on Instagram from PC.
88ROOK
illinois
seems this is the new way they come, i just got a new warranty return and cam e in the plastic box. also the smaller box means you dont get the lanyard with it. my first one came with the lanyard
G
gilleydog
florence az
2017 ram larami
talk to Matt it just the way PC sends them I guess they need to cheap out !!!
Nick@GotExhaust
Supporting Vendor
SC
This is PC's newer packaging. They are NEW, so no worries there.
BOB RAM 2500
2018 2500 4X4 CREW
HEMI 6.4 with 456
So I must play dumb. What does the PC actually do? Easy to set up? Why have one? 2018 RAM 4X4 6.4 W/456 GEARS
Nick@GotExhaust
Supporting Vendor
SC
Mainly it takes the delay and lag out for the pedal. Makes it feel more like a throttle cable rather than drive by wire. It will give you much more responsiveness and more seat of the pants feel. You can look it over here and if you choose to order use promo code PC5 at checkout
https://gotexhaust.com/i-23645471-2...ottle-response-controller-pc31-bluetooth.html
tomb
ontario canada
2012 bighorn-cherry red
I am still on the fence on the PC -please someone push me to one side or the other!!
ThunderMug95
North Prince George, VA
Look, this is single-handly the best mod you can do for your truck. Plugs into top of oem accel pedal and then the oem wire plugs into the opposite side of harness.
Set it to Sport, +1. You will SMILE YOUR ASS OFF. It cuts down on your pedal lag by 100%. Whether from a dead start or kickdown passing on the highway. If you pull up your Pedal Commander equipped Ram next to a non-equipped at a stoplight you will absolutely holeshot the other one. Its electronics are faster than any human foot press could be. Removes in seconds for dealer trips and leaves no trace on computer.
BigRed4x4
Mid Michigan
I don't have a PC and my 2 year old tires look brand new. Can you guys with a PC say the same? I doubt it so just be prepared to chew threw tires.
gville35
