Pitman Arm question
Ironcross
USA
6.7L
Howdy everyone! I have a 2012 Ram 2500 cc long bed. My truck is lifted 10” and I am running into an issue finding a drop pitman arm that drops enough. I’m currently running one made for an 8” lift and I’m rubbing my sway bar inlink pretty bad. Has any seen or own of a pitman arm made for a 10” lift? Thanks!
BolletuH
Wyoming
Try McGaughys or Kelderman. I think both make pretty tall lifts so I would assume they have either found or manufactured a pitman arm for their higher lift systems.
olyelr
Kewadin MI
What is rubbing the sway bar links?
If you find a bigger drop pitman arm you will have to snag the corresponding drop mount for the track bar as well. Otherwise you are gonna get bump steer.
