Plasidip Exhaust Tips
99RamSport360
5.9L Magnum 360
Okay, so I found plastidip for only $5 a can, and decided to buy a few cans...
Do you think I will be able to paint my exhaust tips without it coming off from the heat?
thanks
Musclemckeester
Houston, TX
n/a
n/a
I have seen somebody do this, but I don't think it's really recommended for high heat. A better option would be to use some high heat paint for an exhaust application.
Davy120
fairchild afb
Yes on anothet forum im on quite a few people have plasti dipped exhaust some for over a year and it's still holding strong
Sent from my MAN CAVE using Tapatalk 2
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
There's been multiple people on here do their exhaust tips with no problems. At least on the 4th gens from what I've seen.
99RamSport360
99RamSport360
5.9L Magnum 360
Yeah, I have been reading on it, and a lot of people have done it. The only reason I won't high heat paint them is because they are all stainless, so paint doesn't stick to them, and I don't want to etch them with acid, and I had heard of this being done. I also don't want it to be permanent if I don't like it. I went to the performix website ( Plasti Dip Tech Tips | Plasti Dip International ) and it says that it has been tested to 200+ degrees, and after driving for 30 minutes, I can still touch them with my hand, so I think they will be alright
milleraddison
Hemi 6.1
plasti dip is good up to 200 degrees F. Your exhaust gets way hotter.
blackout11
alpharetts GA
2011 R/T
id suggest not doing it i did mine it held up great i took a 5 hour drive and it cracked and flaked off
TheMaddog
DFW
i did it to mine, then i took it off. no problems.
TMFMK
