Platinum's really, really suck
RAMnCali
SF Bay Area
I just finished my 2nd spark plug change, and I'm really disappointed in Napa Auto Parts. I replaced my plugs at 35k with the ones recommended by Napa. I only got 6 cylinders done, and I had back spams for a couple years so I never did replace the last 4 plugs. After joining the forum, I learned more about plugs, and my performance seems to be worse than other Rams in MPG so I replaced with coppers at 55k. Here is a side by side of copper with 55k on the right, and platinum with 20k on the left:
That's one big difference!
S2kiHemi
Houston TX
Hemi's don't like platinum plugs so that could be the problem.
USMC1188
SW Ohio
None
Truckless...
Always use the factory Champion Coppers on the Hemis, it's the only thing they like.
That is a HUGE difference between the two.
truckin151
2013 sport
Yup copper are the way to go. The NGKs are pretty good on N02 from what I've read as well.can't really say how they are on a non nitrous system though as I only run the champion plugs, cheaper and they work well.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Champion on older Dodge's and NGK on new ones always copper seems any other "upgrade" screws them up I have no idea why. If you can though NGK plugs are much better than Champion if you have a choice.
MADDOG
Living in a Firepit
6.4L HEMI
A lot of HEMI owners have found the same thing. The engine just likes copper plugs best.
RAMnCali
RAMnCali
SF Bay Area
I'm convinced, and glad I decided to swap 'em 15,000 miles early...what a difference
LB3711
Trumbull, CT
3.6L V6
all that black even past the threads tells me that there is another problem. They were loose and there was bypass
quietpeen
2021 TRX
Hellcat
How much did you pay for those platinum's? I bet that is why napa recommended them.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
I learned the same lesson with 2 x colder, wasted 225$ Canadian. I will soon find out how the Crazy Spartan Cam will act with coppers when I drop her in the R/T.
WhiteExpress
Midland, TX
I agree. My Dad's truck was misfiring... I start with the easy things, lets look at the plugs.
Crap-tastic Autolite Double Plats. Who the ____ put those in there?! Some yahoo in Arizona. Didn't clean anything for a crap, dug a grain of sand in nice and deep (felt cross threaded). Idiots.
Threw in some NGK V-powers (basic copper) and the truck runs GREAT!
RAMnCali
RAMnCali
SF Bay Area
That was the worst looking platinum plug, and the last 1 installed, so it may not have gotten the 2nd check for tightness. Would that usually throw a code or cause other problems? Spark plug boot was in good shape and everything looked ok, anything else to check?
