Plugs and wire recomendations ???
gesjr
maine
I have the 5.9l and just ordered some goodies. Going on all at once will be a volant cai,butler&mcmasters 52mm throttlebody,magnaflow y pipe,new tps,sct tuner,,hughes plenum repair kit ,180degree t stat,sonnex line booster,trans tune up and adjustment at the shop. Any suggestions on plugs and wire to go with these mods? I have heard good things about taylors. Been saving for awhile to do all this,the mod money is now gone!! Time to start saving again . Haha
HemiBabe
DFW
Well, I'm not too sure about the 5.9's but I have the Taylor Shorties and I like them a lot
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
just plain copper plugs work best in our engine none of the fancy stuff
txbass06
NE Texas
5.9 Magnum
^^X2. Either the OEM Champion plugs or a set of NGK copper. I'm running the latter with a set of Mopar wires
427invader
Shippensburg, PA
I just replaced my plugs with the OEM Champion copper plugs and the wireset with Taylor's Thundervolt 8.2mm. My truck has the 5.7 Hemi.
WhiteExpress
Midland, TX
I ran on my 12+ Magnum motors the NGK Copper plugs, Echlin Brass Cap / Rotor (brand doesn't matter, just get the 'good' one with brass contacts) and the STOCK SIZE plug wires. You aren't increasing the charge, you don't need 8 or 9.5mm wires. Just get a good set of stock size wires. (I use Napa Beldens, but I worked at Napa)
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
agree with a couple here. brass cap and use the cheap stock champions. they run the best.
Synical
ny
4.7L
i'm running in my 4.7 the BOSCH platinum 4
