Robert Morasko
I took my 2011 RAM 1500 Laramie Longhorn with 130,000 mikes to replace fuel pump. No evap codes until mechanic replaced fuel pump. I continue to receive PO 456 and 440 despite replacing fuel cap, replacing purge Cylenoid, Smoke test shows no leaks, pressure test shows leakage or need for fuel injector replacement, replaced fuel pump again under warranty and several trips to mechanic to make sure hoses are tight. Continue to receive codes. Any suggestions I can share with my mechanic. Thanks, Bob
