Poll- What Weight Oil do you Use?
What Oil Weight do you Use?
  • Total voters
    134
  • Poll closed .
We have seen Ram recently move eco diesels to heavier oil due to internal issues, and we have similar issues with hemi's and Cam/lifters imo. So just curious to see a poll on oil weight. If you go heavier then 5w20 have you ever had any issues? Trying to see how many people have had any issues with a heavier oil with these mds engines that are supposedly dependent on 20 weight oil. The poll closes in a year and you can change your vote if you end up with a check engine light.
Thanks in advance for your participation.
I started with 5w20, then moved to 5w30, and then I went from 5w30 to 10w30 and no CEL's - so far.
Ramnewbie
I started with 5/20 but since then I've run PP, Amsoil SS, and now M1 EP all 5/30's with no MDS problems. The 5/30's also cured alot of the noises I was getting. Little to no fuel milage difference and if anything engine runs a little cooler.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
I have a 2500 with the 6.4 so they state ONLY 0W-40 & special specs of which I think there are only 2 oils out there that meet these specs. Something to do Unicorn Tears?!? LMAO
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
7 quarts of 5w30 with no issues.
4qts 10w30 and 3qts 5w30 no issues
CanadianNick
4.7 V8
BEen using PUP 5w20
I stocked up on PUP 5w30 last time it was on sale so it will be 5w30 from here on
tantore
texas
i was using valvoline 5w20 went to red line 5w30 a few thousand miles back no issues at all happy with the red line 5w30 will stay with it
huntergreen
Marine Corps Navy Badge
Using 5-20 pup. So far engine is smooth and quite.
grizzstang
Calgary, Alberta Canada
Running 4 PUP 5W20 and 3 PUP 0W40 right now (around a 3W28) but I will be changing the oil in the next few weeks.
I might run 7 PUP 5W30 or I will mix again but run either 4 or 5 of the 0W40 because is has more moly than the 5W30.
I have around 3700 miles on my currant OCI and the motor is nice and quiet on my mix.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Dodge Ram 5.7= 5w20 Amsoil ss
GMC 6.0 = 5W30 Quaker State Ultimate Durability
Both oils are serving/served me well.
Rampant
NJ
392 Hemi
You may want to change the title of this poll to 5.7 and/or 1500 model specific if that's the data you're looking to collect. The 6-banger and 5.7 only account for 2 of the 5 engines installed in Rams across the 4th gen lineup. Coincidentally, they are the only two in which the manufacturer has specified the use of a 20wt oil.
burp, I mean bump
Ramnewbie
Going to update my previous post. Have now went back to 5/20. The 5/30 ran good, no cel, everingthing good except cold starts. On cold starts it sounded like rocker arms running dry till the oil got pumped up there. Put M1 EP 5/20 in and no more noises. SS 5/20 on the shelf to go in next oil change.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
So what has been your temps on your cold starts with the 5w30. ?
Ramnewbie
Anywhere from 50 to 15. The temp didn't seem to make that much difference. On the initial start it would be quiet for for 4 or 5 seconds then you could hear the rockers for a couple of seconds, then it would get quiet again. Outside temp didn't seem to matter. On a restart after engine was warm it wouldn't do it. Now with the 5/20 everything is quiet.
mvm2
