Power Steering pump
kicker417
galveston,tx
I am about to replace my second power steering pump in my 2008 with only 57,000 i was just wondering has any abody else had this same problem:superhack:
southernbnb
i have changed one on my 04 and im at 57,*** on the odometer. all i can tell you is make sure you get the pulley pressed on all the way. mine ate my serpentine belt before i realized that the pulley was screwed up. doh!
cheapbeater
Wisconsin
i remember hearing something about this.. like bnb said, if you dont get the pulley on right it will wreck the pump because the belt will be rolling at a slight angle on the pulley. if i were you, id just buy a pump with the pulley already on it...
