WilliamS
Its about finesse. You dont put the spray head on the motor, our guys do it from about 3 feet back. A spray nozzle on a water hose would roughly be the same. No less we use pressurized water on the engines daily.
I just spray everything down with undiluted purple power and let it soak. Then I'll wash it off with hot water on a cold engine. If you do it when the engine is hot, it tends to leave water spots on all the metal parts from the water evaporating so quickly.
As far as covering things and removing stuff...I don't even bother. Think about...we drive in the rain and drive through puddles. I just hold the sprayer back far enough where it's not blasting anything, and kinda spray over the sensitive stuff indirectly.
I wash my engine bay once a week, that way grease, oil, and grime never even has a chance to build up.
Sir , where did you get your RED Radiator hose ?This is how I do mine every 3-4 months you could eat off mine.
I have detailed show trucks for the past 12 years and I'd personally never power wash and engine compartment.
Most of these guys advise is spot on but check out "Chrisfix" on YouTube. YouTube search "super clean your engine bay-Chris fix" the video in a split picture of a dirty/clean engine bay. Goes into detail of how to do it the absolute best and safe way. And easy to watch as in it's not boring actually kind of entertaining and professional grade editing
