power window contril
Bduemig
South Dakota
All of a sudden, I can only control my windows from driver's door. I tried the window control button but it did not help.
Any ideas for troubleshooting?
Bduemig
Bduemig
South Dakota
Fixed
I found a few videos on YouTube that showed how to fix it. Seems like a common problem for 2002 to 2005 Ram trucks.
There are two solder joints connecting the window lock switch to the board that crack and either make windows other than the drivers panel inoperable.
You pull the panel, re solder the two joints and the problem is fixed. Fairly easy job.
AnEngineer
The button for the lock on mine would not latch so i took it apart and soldered across the leads for the lock instead of messing around with the button
joshhhh
