Powerwagon Trac Bar
1500ram12
5.9L Cummins
I was wondering if someone with a 2013 or newer powerwagon would be willing to measure their front Trac Bar? From center of the bolt to center of the lower bolt, and just in case measure from outside to outside of the entire Trac Bar.
1500ram12
1500ram12
5.9L Cummins
Thanks, I appreciate it.
DannyMK2
Long Island, NY
2015 Power Wagon
got some rain yesterday evening and couldnt get under the truck. as long as its dry today ill take the measurement when i get out of work.
1500ram12
1500ram12
5.9L Cummins
Sounds good
DannyMK2
Long Island, NY
2015 Power Wagon
38 7/8" from center to center of the mounting bolts. measuring the whole track bar is tough when its installed, but roughly 42".
1500ram12
1500ram12
5.9L Cummins
Thanks. Looking to add a leveling kit and don't want to drop $350 + on a adjustable Trac Bar when a pw Trac Bar is around $170
1500ram12
1500ram12
5.9L Cummins
I wouldn't of thought of it but I was going through the local dodge dealer seeing if anything nice came in on trade and stopped at a pw. Started thinking, hmm. Pw sits about 2" higher than a regular 2500. So jumped on allmoparparts.com, found PN for both. Once I get my truck back from the body shop I'll me measure up mine and see what the difference is.
DannyMK2
Long Island, NY
2015 Power Wagon
it should work. i think ive read about some guys doing that on cummins forum. the downfall is that you cant re-build the stock track bar. not sure how long you plan on keeping your truck but in the long run it may pay to buy an aftermarket unit. your truck is fairly new why not run a track bar drop bracket until it wears out? just curious.
1500ram12
1500ram12
5.9L Cummins
I haven't seen any drop brackets for a 2"-2.5" kit. Plus I rarely keep them longer than 3 years. Past 3 just made it past 2
