Premium 7" evic cluster speedometer REDUCED SOLD
Status
Not open for further replies.
Nathan Haslag
missouri
I got another 7" evic upgrade available
It's from a 2013
I plugged into my 2017 to make sure everything works
63523 miles
In perfect working order
Should work on all 2013-2017 ram trucks that are gas models
Screen has light scuffs, normal wear nothing bad can likely be buffed out or left not very noticeable
Tpms will not work on newer model trucks but everything else will
$225 shipped
shortman
*******, GA
Hello... I'm interested and have a 2013 Sport 2WD.... But have a couple of questions....
I have a CO worker that has the same 2013 Sport and his has the above cluster and mine looks similar but doesn't have that gauge to the left center under the volt meter.... I apologize in advance for this question but what else is different on this cluster? Or... Maybe the better question is how many different clusters are offered? I recently had the air bag recall done at the dealer and I asked the service manager about the differences in the clusters and he didn't know....
N
Nathan Haslag
missouri
You should be able to adjust it to show those in the options somehwere
I would have to check but if your cluster looks like this you can edit the screen to show what you want on the dash
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
I have the same 7" evic from the factory and can select which 2 guages appear in that spot under the 'setup' screen.
There's a semi dedicated 7" Evic upgrade thread around here somewhere and I'm nearly 100% certain that the cluster PNs changed in 2015 where the Tpms won't work on 15+ with this cluster (as pictured in the OP's 17 truck), but everything else will, so ...
13-14 clusters work with 13/14 Tpms
15-17 (&18?) Clusters work with 15+ tpms
I bet @R.L.K. can confirm.
M² Mods.
silver surfer
South Brunswick, NJ
'14 cluster will work on '15-'17 tpms. I put a '14 cluster in my '15 Express. Also, I think late model '13s also. Not sure on that one
shortman
*******, GA
M² Mods.
Well then... I guess I need to grab some coffee and go sit in my truck and see if I can figure this out.
mondo
Columbia, Pa
2014 2wd express rcsb
Do you know what it takes to get the miles changed to what is on the truck? Trip to dealer?
silver surfer
South Brunswick, NJ
Talk to Dominick at tvandnav2go.com for programming. He is the best in the area (shop is in NY). I think his charge is $175 including return shipping. Quick turnaround. I went to the shop and did the reprogram/swap in the parking lot. Whole process takes about 15 minutes. Most dealers won't do it.
mondo
Columbia, Pa
What part of NY is he in?
kad
Hudson Valley, NY
5.7L HEMI
Just a little info for anyone interested. According to the parts sites I looked them up on, there was a changeover in part numbers between 2013 and 2014 and then again between 2014 and 2015. The same part numbers then go through 2017, which is as far as the two sites I used went. From what I've read in other threads, the change in TPMS was between 2013 and 2014 so in theory any 2014+ cluster should work fully in any 2014+ truck. I don't know what the change in 2015 was, if it was just cosmetic or of if there is a functionality difference.
-K
This list does not include the special colored trims like the Rebel.
2013:
56046544AK - 7 DISPLAY, PREMIUM
56046542AK - 7 DISPLAY, ULTRA-PREMIUM
56046544AK - RAM 1500; W/ O LONGHORN SERIES; W/ PREMIUM PACKAGE
56046540AL - RAM 1500; W/ O LONGHORN SERIES; W/O PREMIUM PACKAGE; 7.0 DISPLAY SCREEN
2014:
56054945AG - 7 DISPLAY, PREMIUM
56054946AG - 7 DISPLAY, ULTRA-PREMIUM
56054946AG - RAM 1500; W/ LONGHORN SERIES; 3.6L, 5.7L
(Yes, there are two different descriptions for the same part # for 2014)
2015:
68242849AD - 7 DISPLAY, PREMIUM
68242853AD - 7 DISPLAY, ULTRA-PREMIUM
2016:
2017:
smithj603
Boston
2015 BigHorn CC
-K
Great info, thank you!
Status
noraa73
