Wow, just checked out their site, they really do have some good lookin stuff... I sent them an email, if they come up with anything I'll post it up. Thanks again merc225hp. BTW, I would like to look into the crossover steering set up you mention in earlier posts... any idea on what I'm looking at in $ for a 01 1500 ORE?
Here is a parts list of what's needed, best if you price it out.
Cross-over steering parts list.
3 x ¾”x ¾” Heim rod end right hand thread
1 x ¾”x ¾” Heim rod end left hand thread
3 x ¾” right hand thread jam nuts
1 x ¾” left hand thread jam nut
3 x ¾” x 1.250 Right hand thread weld in ****
1 x ¾” x 1.250 Left hand thread weld in ****
1 x Grade 8 bolt 5/8ths x 6”
1 x Grade 8 bolt 5/8ths x 4.5”
1 x Grade 8 bolt 5/8ths x 3.5”
3 x 5/8ths locking nuts to fit above bolts
3 x 5/8ths safety washers
4 x 5/8ths spacers
6 x ¾”x 5/8” misalignment spacers
10’ of 1.750 x .250 DOM tubing
I might have missed a couple of small parts, I will edit this later if needed.
You will need to find a shop that can cold bend the DOM tubing approx 5 degree on each end of the long cross-over bar. I can get the bend info if needed and post it up.
If you want the one/parts I have pm me, well under a hun plus shipping.
I have also mentioned a F450-F550 conversion but I am still working part numbers for that, only need two more.
* Be warned using either of these steering set-up requires you to dill and or re-taper the pitman arm and both of the steering tre holes in the knuckles. Once you do this the only way to go back it is to replace those parts.
** Check your laws/insurance make sure you can use Heim rod ends on a street driven vehicle.
