Pro comp 6" lift and Bilstein 5100s question
Dirty from upstate NY
Rochester, NY
I haven't been that successful in getting info on my particular situation. I've searched through TONs of threads with no resolve for my issue.
I'm currently running a pro comp stage 1 6" lift. I couldn't install the PA 3" body lift this passed weekend because my amp research boards wouldn't clear. So all I have left is my 5100s and zone UCAs to install up front, as well as the 1.5 spacers in the rear.....which i still need to order. My truck currently has a 1.5" rake.
My question is, do I use the preload spacers as well as the 5100s? The setup up front consists of the pro comp strut spacer and two pre load spacers. I see lots of guys on here state that they have the same 6" lift with bils maxed out. So whats the combo? Do i keep 100% of the stuff my pro comp supplied and just swap out the struts with the bils? Or is there a freaky combo I'm supposed to do? If I dont reuse the two preload spacers from PC, I'll only gain 1.8" of lift? Im confued as F@CK here and need some help........please!
WilliamS
Tampa FL
You can use the bilsteins, you wouldnt use the preload spacer the kit comes with. This will actually let the truck ride better as well wont stress the UCA.
Steve Holtz
