Problem with SuperChips F5 tuner and their support
Tod Guthrie
Emmett, ID
Bought a SuperChips F5 tuner and had a problem right off. Under light throttle and stock tune the trans shifts at around 2000 to 2500 RPM across the board. After tuning 1-2 and 3-4 shifts happen at that same RPM, 2-3 is 3000 to 3500. Also it won't shift out of second until about 30 MPH even around town. Went back to stock and no problem.
After 2 emails and a VM, I finally got a hold of support and was told it's a problem with my transmission. The tuner is not the problem it's just making my transmission problem more obvious.
There are no mods and the trans was rebuilt about 50k ago and never any issues with differing shift points.
Last 2 tuners I had were Diablosport. Both had minor issues (well one was more major) but tech support had me datalog and actually modified the tune to resolve the issue.
Did I just get a lazy tech or have you run into similar?
Bottom line I guess I have to go with a different brand.
MADDOG
Living in a Firepit
6.4L HEMI
Sounds like a lazy tech. Call them back and see if you get a different result.
T
Tod Guthrie
Emmett, ID
Just contacted their eBay store where I bought it, it is the company's store not a reseller. Explained the problem and said if support won't try a little harder I want to return it. They just responded and said return it... too much work I guess.
Time to research alternatives.
T
Tod Guthrie
Emmett, ID
Just picked up the Diablosport Intune i3. Tuned it this morning, no problems with the trans, shifts at the same RPM across the board. Guess my defective transmission magically fixed itself.
Was a bit concerned when I found out both Superchips and Diablosport are owned by the same parent company. Even use the same updater software. Must not use the same tunes though.
