Projector/Led Tail LIght issues
ramalamadingdong
2017 1500 Big Horn
I recently purchased OEM Projectors and Tail Lights as well as the Retro Shop adapters. Everything was working fine until I got the Parking Light Out message. Initially it was just the front driver side, where the LED parking light would go out but the blinker, etc would still function. I spoke with Retro shop and they are sending me additional resistors to alleviate the problem. Now today I got the same message but the rear driver side parking light was out, again everything working otherwise. Retro has been super helpful and not complaining about them in any way. I'm just curious if anyone has had this issue before as I can't seem to find too much about this? Thanks
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
I had the same issue. Jeremy sent a stronger resistor, and no problems since then. Also, make sure your grounds are REAL good.
R
ramalamadingdong
2017 1500 Big Horn
Yeah he has been really helpful with this. Are there grounds with the new resistors? The adapters were plug and play so I did not have to ground anything.
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
for some reason some trucks are more sensitive than others, my 13, my 14 and my dads 17 dont even tell you anything about the parking lights, when other trucks will tell you about every bulb on your truck
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
The new ones don't, all plug and play
dearchristopher
Galveston, TX
having this exact same problem now...
my cluster doesn't tell me there is a problem, but I will get flagged and told that my running lamp is out at night. usually its the passenger side one that it happens to, but I flipped the harness to the driver side in an attempt to diagnose, and it happened there too. so now it happens on both sides.
jeremy sent me another resistor to wire inline, but it doesn't seem to have done anything. this pic is taken after the resistors were installed and intended to fix. I hate it, but I might be selling and going a different route.
Spud2388
Raleigh, NC
2017 Sport
So I have never been a fan of using resistors. Adding something to my truck that gets hot enough to melt plastic is never good. So what I did was when I changed over to led bulbs, I picked up 3157 bulb sockets with the pigtails and tapped into the stock harness. This allowed me to keep the regular bulb, which would keep the computer happy, and still let me use leds. I did this on each corner (brake and turn). My reverse lights never tripped anything. It might be different since you went with a whole new housing, but might be something to think about.
Demon-HeMi
Houston
basically you did the same thing resistors do, those light bulbs can get hot enough to melt plastic just like a resistor, you virtually did the exact same thing but yours have the ability to burn out unlike resistors.
resistors are great, and they will only melt something when not installed properly, ive never had mine melt anything on my truck
Demon-HeMi
Houston
this was my 3rd brake light from leaving my cargo light on, and if you look at the inside of a lot of tail lights, the housing deforms from the heat of the bulb, so like i said you are doing the same thing as a resistor but yours will burn out much faster than a resistor will fail
Graygoose
Oklahoma
Convert, for now.
small
Ouch! ^^^
dearchristopher
Galveston, TX
I drilled a small hole inside the taillight stamp for the bed and mounted the resistor on the metal. no heat issues yet. I do have the odd malfunction though.
