Projector light upgrade
Syke001
I recently upgraded my head lights to projector lights added the resister to ground and parking light and now my blinkers only work when switch is in parking light mode
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You likely need a different harness or correct the programming using AlfOBD. Do you have a link to what you purchased?
S
Syke001
I do not it was a gift from last Xmas I just bought the load resisters (50w-6ohm) to stop the light out message which it did.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Were they OEM reproductions?
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Did you have to go into the BCM with AlfaOBD and reconfigure the DRL's? / reconfigure for LED 's or do the DRL's have an separate power feed / circuit?
If you changed and wiring, sure would like to see what you did. Otherwise everything here is a guess.
