Projector lights
Chadpoe2002
Russell springs kentucky
HELP? I just bought new 2013 oem style ram projector headlights from protuninglab and new adapters from retro shop. Installed them today and when I hit my brake peddell the passenger side led park light comes on. The only way to get the park light to go off is to remove passenger side brake/tail light. far as the headlights,park lights and turn signals still work fine. I check all body grounds and they are tight. Please help!
JB1
Houston, Texas
Maybe those lights are halogen replacements, did you try it w/o that adaptor harness?
Chadpoe2002
Chadpoe2002
Thanks. My truck had the dual lights. I tried switching harness no change also swapped the driver side light just to see if it was the led board but it also lit up I think I might have a ground in my truck wire harness
Chief_6.7
It definitely sounds like a ground issue
Chadpoe2002
Chadpoe2002
Thanks. And Yes I just can' seem to find a ground anywhere. I just ran a new wire from fuse box to the park light wire. And I will fix the ground when I find it
