PSI for 37” tires on pavement/Off-road
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
Hey everyone,
Just wondering what PSI everyone runs their 37”tires on pavement and off road, if you have 37s?
Thanks.
kurek
Northwest
Easy way to be sure for your specific tires/truck
muddy12
Indiana
Been chalking my tires for years, works great every time. Best part is that it gives you the best pressure no matter what size tire you are running.
If I’m being totally honest though, I start with the chalk test, then keep a close eye on the tread wear for the first thousand miles or so, and adjust psi as needed.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I have 35's, run them about 42-45.
22hemi13
Tucson AZ
2014 2500 4x4
37’s on my 2500. Run about 40. It’s gonna vary on what you carry too. Chalk is the best. Go lighter on rear unless you load all the time.
6.7CumminsDrvr
The Dude abides………
Georgia
Take a look at a load inflation table. At the very least, it I will give you the minimum pressure required for the tire to carry a specified weight.
Toyo has a pretty good one.
What size are your rims and how wide of a 37 (12.50 or 13.50)?
https://www.toyotires.com/media/2125/application_of_load_inflation_tables_20170203.pdf
And just in case anyone is wondering, the max load of the factory P275/60/20’s is 2,365 lbs...........not 2,601 lbs. “P” metric tires are de-rated by a factor of 1.1 when mounted on a truck.
ram1500rsm
Trabuco Canyon, CA
I run my 37x12.5x17 BFG KO2’s at 32 psi cold daily. 28 psi for hi speed dirt trails or geneal offroad. 15psi on sand dunes.
ram1500rsm
Trabuco Canyon, CA
I use that table all the time.
37x12.5x17 LT tires at 32 psi=2584lbs and more than plenty to carry my truck around :)
